Just because I am now am really worried...What tube is this?
Todd_33
Todd_33 Member Posts: 69
Doh...
CSA Canadian standards association..
b137 ? B137.0-05 Definitions, general requirements, and methods of testing for thermoplastic pressure piping
I can tell what is after the B137, I am guessing that it falls under
B137.8-05 Polybutylene (PB) piping systems for pressure applications
1 Scope
This Standard covers polybutylene (PB) pipe, tubing, and fittings. Nominal pipe sizes (NPS) covered are NPS-1/4 to NPS-2. Fittings covered include insert-type fittings, socket fusion fittings, plastic-to-metal transition fittings, and compression-type fittings. Pipes, tubing, and fittings covered by this Standard are intended for use in pressure applications such as hot and cold potable and nonpotable water distribution systems operating at a pressure of 690 kPa and at a maximum temperature of 82 °C.
So poly butyl tubing.. I am going to assume. So no oxygen barrier.
Derheatmeister said that limits my choice of boilers.
  • Todd_33
    Please look at this pictures to help me determine the type of tubing....I am worried...
  • Steve Ebels_3
    Steve Ebels_3 Member Posts: 1,291
    Hmmmmm
    Any numbers, lettering, brand ID on the tube?
  • Todd_33
    I don't see a thing... nothing zip nada...
  • Looks like...
    regular old nylon tube to me. used a lot for things like the ice maker hookup on your fridge. I don't necessarily see it as a problem as long as it's carrying potable water and has nothing to do with your hydronic heat.
  • kpc_38
    kpc_38 Member Posts: 4
    there was....
    a brand of polybutylene that was silverish in color.
  • Todd_33
    Puke,
    it has been for 14 years...
  • What do you mean?
    Heating system for 14 years?
  • Todd_33
    It has been fine in my hydronic heating system for 14 years now. I have 3 of these manifolds spread throughout the house, in addition to the main manifold in the utility room.
    As I contemplate a boiler replacement, I was trying to determine the type/brand of tubing. The only thing we new at purchase time (1998) was to avoid Entran. New questions have been raised about oxygen barrier/non barrier tubing..
  • Right,,,
    My guess is you have non barrier which is supposed to cause premature failure / excessive corrosion of iron components, especially the boiler. Can't be sure about the barrier thing unless you have a way to trace it back from whence it came.
  • Todd_33
    I need some patience... Wait for Richard to stop on by and give me a diagnosis/prescription. Non barrier tubing is not the end of the world, just another thing that needs to be worked around..
    I have spoken to three different contractors in the past few weeks, and at least 4 different contractors have worked on the system in the last 12 years...
    Richard/Derheatmeister is the only who has any answers that make any sense. Heck he is the only to have asked any questions... Seriously.
    I am just wound up that I have spent thousands trying to band aid something that was never set up right and no one has EVER really given a straight shooter solution to the problems...
  • Todd_33
    I broke down and cracked a valve to sample the system. Clear with a distinct anti freeze smell.. 10 years on it, no chemistry ever done it. No brown rust at all...
    I guess I will never know..
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Clear Fluid
    If the fluid is clear and has no rust that is a good,also your expansion tank is the original one
    I will know in a couple days when i can make it to Leadville looking forward to it!
    Maybe i can find some kinda information on the tube?? Richard
  • Possible ID
    There is/was a pipe on the market called Hydronic Alternatives. It is a 5 layer pipe with an oxygen barrier, and is silver in color. Some of the info on the pipe is: PEOC-Plus PE-RT Dowlex 2388, DIN 4726, ISO 10508. Rated as 90psi at 180°F Made in Germany
    Hope this helps!
  • Right,
    no corrosion in the system is a good sign! :)
  • Ted G
    Ted G Member Posts: 63
    I have a roll of that PERT pipe, but I think it's black.
  • Mark_7
    Mark_7 Member Posts: 123
    Looks like Infloor pipe which being that old it would not have a barrier.
  • Billy_10
    Billy_10 Member Posts: 7
    Burnham Mega Steam install?
    I may not do this install myself, but I am trying to understand it better. Here is my situation. I had a 70 year old oil steam unit that was 2000 lbs. when I finally removed it. It may have been 10% efficient at best. Most of the heat ran up the chimney. When I separated the sections, the bottom 2" connections were rusted with sediment almost solid.
    My house is 2600 sf. I did a heat loss and came up with 46,000 btu's. EDR calculation came out to 300 sf (72,000 btu). The boiler I think I need is the Burnham Mega Steam 396. What other calculations do I need to take into account. Is this too small of a unit? Also, I have attached a diagram I created to understand the supply and return.
  • Todd_33
    Some numbers found
    What appears to be a SA in a small circle followed by what seems to be 613/R5
    It is clear, if you shine a light through it it is opaque. The silver appears from when the gypcreted the floors..
  • That it does....
    But one thing for sure, you have THE right techno-mechanic in Richard working on it. I'd (HAVE) trust him with my life.
    Actually, in my 35 years of hydronicing, I have never seen PB in anything but grey, not clear. ANd it usually has so much pigmentation that you cannot shine a light through it. I suspect you have some grade of PEX, and if you can not determine whether it has a barrier or not, assume it doesn't.
    ME
