can you use a instant hot water heater to run a baseboar loop
Timco
Member Posts: 3,040
Rinnai is absolutely rated as a heat source, and there are many piping options to accomodate your DHW with the same unit as well as hydro-air units. Check out their website. Great stuff and really easy to maintain...just be sure to perform regular maintainance (clean) the HX....the gas valve is fully modulating. Also, be SURE to use a x-tank and a 30# relief valve...NOT the T&P the unit will likely come with....
Tim
Tim
Just a guy running some pipes.
1
i am doing a pretty small loop of baseboard at the max i would need 70,000 btus to do it all comfortably, i heard there is a rinnai that can be used as a small boiler, has anyone done it?0 -
Do you mean a Tankless Water Heater???????
Many folks confuse the two. Mad Dog
yes i do mean a tankless water heater, can it be done0 -
yes.
just don't use the same tankless do do your domestic w/o seperating the waters. Plumb it like you would a normal boiler.0 -
Tankless Water Heater/Hydronic Heating Use
Research this further with your supplier, but I seem to remember from a Rinnai class that the warranty changed if it was used for hydronic heating.0 -
70,000 btu doesn't really sound "small" to me.
Tankless water heaters are designed to greatly raise the temp of a small amount of water while boilers are designed to (by comparison) lightly raise the temp of a large amount of water. Try to move a lot of water through a tankless in order to pack in those BTUs and many will have extraordinarily high head loss requiring a very high-powered (and energy hungry) circulator, and I'm not even touching on the greatly increased velocity inside the HX. Study manufacturer literature very carefully before using.
Plenty of "real" boilers (both conventional a condensing/modulating) that are reasonably suited to such a loss.0 -
Do not be cheep just buy a boiler.
Instand waterheaters are based on setpiont not Outdoor reset!
Seen to many problems with these kind of installs!0
- 120 Geothermal
- 396 Solar
