Ultra V3
I just saw it at a show yesterday, and infact bought the display. Its a United Technologies control, same manufacture of the WM CG/GV control. The story I got was the Honeywell control was being made all over the world and the UT is made 2hrs from WM in Mich, and WM wanted to be able to do more with it than Honeywell was willing to do. Very easy to program, has a lot more parameters. The best thing is it can do 3 different water temps of the control. Also, dual sensors on the Supply and Returns, for redundancy to avoid lockouts from bad sensors. The wiring is also now in FRONT of the vent, not behind it. Very cool!
Andy
Riverside Mechanical, LLC
  • adambuild
    adambuild Member Posts: 422
    W/M Ultra V3
    What's the deal with the W/M Ultra V3? Is it a new Honeywell LCD control and display? Who makes it if not Honeywell? Any better? Any worse? Different to program? If new and improved, will TT Prestige and othe mod/con mfrs follow suit?
    Thanks in advance, Adam
  • Tony_23
    Tony_23 Member Posts: 1,033
    I'm impressed
    And that takes doing :)
