Bladder tank conversion
Mr Steam
Mr Steam Member Posts: 3
What is the correct sizing method when converting from a compression tank to a bladder tank?
  • Timco
    Timco Member Posts: 3,040
    Honeywell has a sizing chart for their tanks. Your rep should be able to help as well. You need to know the size, length and number of runs and radiation type...BTUs and system capacity are the factors...
    Tim
    Just a guy running some pipes.
