What is causing a deposit of \"gunge\" which is driipping frm vent
high efficiency boiler?
  • ned sweeney
    ned sweeney Member Posts: 1
    gas boiler \"residue\"
    there is a persistent water drip form the outer wall vent of my gas boiler. This is leaving a "gunge" deposit at the base of the wall. If nothing else, it is unsightly, but i suspect it may be more important than that. the heating system is working fine.
    any advice would be appreciated.
