Steam Radiator doesn't connect
isn't the radiator now at it's original height and could the the pipe be levered up to connect?--nbc
  • Ted Robinson
    Ted Robinson Member Posts: 126
    Mismatched radiator and valve - photo included
    Radiator coupling leaked, for a long time. Floor structure rotted and totally replaced. Now the radiator is too high for the valve coupling by at least 3/4 inch. The valve is at the max height. See photo.
    Do I counterbore the floor for the front legs, to nearly the thickness of the oak boards?
    Is there a short 1 1/2 inch female / male coupling to raise the valve?
    Buy a new radiator that has a shorter coupling height off the floor?
    That 11 section radiator is a beast to move for this deskjockey grandpa.
  • Timco
    Timco Member Posts: 3,040
    Allthough I have never looked at the x-section of a rad section, I would think you could die gring (cut) the legs off enough for that difference, or counter sink the floor. Not much option here. Were the new boards thicker than the orig floor?
    Tim
    Just a guy running some pipes.
  • bob young
    bob young Member Posts: 2,177
    rework connection
    install new valve , remove 45 * & roll connection in with set of TWO new 45* s . new offset will provide correct elevation & setback.
  • Peter Zelchenko_2
    Peter Zelchenko_2 Member Posts: 35
    Mismatched height
    The supply pipe is up-limited by the floor joists the were notched during installation, in 1927. The pipe is leaning off the vertical. There is no access into the crawl space below. (It was open when I replaced the local area of very rotted sub floor.)
  • John@Reliable_14
    John@Reliable_14 Member Posts: 171
    This might work.............
    if the radiator and pipe use to fit try this, put a pipe wrench on the pipe, now put a small piece or two of wood under it , now take a 2x4, 2x3 about 2' long and wedge it between the wood and wrench, put some pressure on the long piece of wood, (now your lever) with your foot and the pipe should move up for connection of union.
  • jimmac
    jimmac Member Posts: 53
    mismatch radiator valve
    Get an extension coupling.They are widely available at a supply house.While your at it replace the valve and spud completely.Easy one!
