Help in identifying a Pex brand
Colin_5
Member Posts: 1
We have a pex pipe that we can't identify the manufacturer. The pipe is labled "7/8 radiant co hydronic heat exchanger tubing". Can't find radiant co on the web.
thanks
thanks
7/8\" Tube
Is it this stuff? As far as I know, the 7/8" tubing was not designed to be used for hot water heating. I think the fittings are just barbed fittings with hose clamps. Doesn't inspire a lot of confidence. I would be wary of the connections in that system, particularly if glycol is involved.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
