Copper Steam Headers
Hey Gerry !
Where other they
"The Lost Art" can I find either an engineer statement or a book , manufacturers instruction that says not to use copper on steam .0 -
Burnham
Glenn S has one, Jim.
Noel0 -
just study up
on cathodes and anodes Jim.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
I understand
The problems with copper headers and all the connected problems. I have a customer who insist in seeing something in a book . And not just "The Lost Art...." They want to see the manufacturer have it in print or an engineering text .9R0 -
Burnham has it in their literature
Keep looking, you will find what you are looking for.0 -
It doesn't say \"Don't use Copper\"
but here it is on page 17: http://www.burnham.com/PDF/8141049.pdf
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
problem clients
some customers deserve to get exactly what they demand. if you disagree, make them sign off on it. and include the grief factor in the price. someone has to do the job , if you don't someone else will.0 -
If it client is going to fight with you then that client for some reason does not trust you. He also won't listen to anything else you have to say. This client feels they know better even though they are hiring you as a skilled steam man. If he knows so much more than you and needs his opinions to be disproven why isn't he doing the work himself ? Once he is disproven, you would've had hurt his pride & now he'll like you even less. He will have you do things his way and blame you later when things don't work as they should even though you knew better from the start. Now your reputation is tarnished for doing such a bad job.
Steam is not worth halfassing just to get the job. It's either the right job for more money or none at all.
I know times might be tough right now with the economy. This guy is not worth it.
Run. Do not walk.0
- 50 Industry Classes
