Gravity-return steam system???
Shane_2
Shane_2 Member Posts: 199
Ok, for the second time this year, And the second time ever, I came across a two pipe steam system with air vents on every radiator. The first one looked similar to the gravity-return system Dan describes on page 125 of the Lost Art.
This second one, I can't seem to figure out what the installer was thinking. There are no thermostatic or F&T traps anywhere in the system. The return side of each rad is hard piped(no return ell, no union); so I don't believe an orifice is installed. The return mains are above the water line of the boiler (3/4"). The returns from some of the radiators are trapped with a dirt leg like I would install on gas piping for a boiler. I attatched a photo of one of these traps.
At this point, I will be repairing one leak on the return piping. The homeowner has reported no problems besides the leak. I found the system to be loud(hissing from air vents).
Any insight, experience, guesses, thoughts, or opinions would be greatly appreciated.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=545&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
