HYDRONIC CONTROL
ED W.
Member Posts: 1
how do i set white rodgers 11B18-101 MAXIMUM WATER TEMP for a boiler.
There are both radiators and baseboards
Is this being used as a
High Limit for a boiler or as an aquastat for domestic hot water? Is this baseboard,radiators, radiant, hydro air etc???
The unit operates between 100 degrees to 240 degrees (F) with a differentail of 5 degrees to 45 degrees if it is a 11B18-101, there is an 11B18-153 which is 35 degrees to 110 degrees.
Need a little more info to help you out.0
- 15.8K Strictly Steam
