EDR for radiator
kpc_14
kpc_14 Member Posts: 38
size. Using the Burnham Heating helper and Dan Golden rules book...I would estimate that @ 4 edr per section or 68 for the radiator....kpc
  • Phillip Biston
    Phillip Biston Member Posts: 41
    EDR for radiator
    I was wondering where I could find the EDR for a Kewanee steam radiator?
    Thanks,
    Phillip
  • kpc_14
    dimentions?
    give us l x h x w...# of sections
  • Phillip Biston
    Each section is 9", wide 30" tall, 1 3/4" thick. Total radiator length is 42" and 17 3 tube sections.
    I couldnt find this rad. in my Every darn radiator book, if I find one similar with close dimentions, will that work?
  • Phillip Biston
    Thanks for the information. This a pretty radiator, I sandblasted it to bare metal and painted it, I couldt believe the detail after sandblasting.
  • Phil_17
    Phil_17 Member Posts: 179
    radiator pix
    how about showing some pix of your rad?--nbc
  • Phillip Biston
    Ok, I will try to post these , I hope it works!
  • That's a column-type radiator
    and it's a beauty! Nice job on the cleanup and paint.
    The closest height in my chart is 32 inches, which would result in a capacity for each "3-column, 32-inch high" section of 4.5 square feet EDR. So the total would be 76.5 square feet.
    You can use almost any column-type chart in "E.D.R." for these. Examples are American "Rococo" or U.S. "Florentine". The one you can't use is for H.B. Smith rads, they were different.
