trap on hot water heater
Mike T., Swampeast MO
Member Posts: 6,928
They keep hot water from rising into the piping via gravity. In other words, the hot water stays in the tank until you open a hot water tap.
You can get special fittings or make one yourself via piping. To pipe a thermal trap, all you have to do is elbow down 18" or so, elbow over a foot or so and the elbow back up a few inches higher than where you began.
heat trap on hot water heaters
what is heat traps used for on hot water heaters0 -
holby rules
A perfect heat sink is 27 " check a holby mixing valve diagram for a detailed illustration0
- 167 Indoor-Air Quality
