insulating steam fittings
Rich L.
Member Posts: 414
If you insulated with fiberglass pipe insulation **** they make fitting covers to match. They come with a diamond shaped piece if insulation that goes around the fitting and then gets covered with a flexible PVC cover. They make a white vinyl tape that seals up the ends. Very professional looking results if you take a little time and care putting it on.
Check this out: http://www.knaufinsulation.us/products/commercial__industrial/pipe_and_equipment_insulation/proto_pvc_fitting_covers.aspx
Good luck, Rich L
Good luck, Rich L
I now have my new boiler installed and have covered the near boiler piping with insulating jackets. What type of insulating material can I use on the fittings?
Thanks,
****0
