OT: snake for fully glazed trapways
bob young
Member Posts: 2,177
general makes the best. we prefer the drop-head style
stubborn commodes
Need a decent toilet auger that won't scratch up toilets with fully-glazed trapways.
Any suggestions of one brand over another?
Thanks.0 -
Interesting question...
The glazing is pretty hard (glass) but of course it can scratch over time...
Maybe a change of diet?
Most quality WC's have fully glazed trapways, but if a plunger or hydraulic ram cannot release a clog, might it be deeper down than the siphon?
I suppose if you had to punt, some vinyl or surgical rubber tubing might give some protection in a pinch but I always think it is the metal corrugations (against metal pipe mind you) that makes a snake effective.0 -
Hydraulic Ram
I'd be careful with that thing if I was you. It will blow the wax ring out at the least, and cover you with who-knows-what in the process.0 -
general thanks
Thanks for the thoughts. Will take a look at the General. Looks similar to the Ridgid.
Brad, the immediate problem is anthropogenic in origin, but not digestive in nature, so recommending a dietary change won't help. 'nuff said.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
