new steam boiler wont turn off at t stat
Leah Frances
Member Posts: 11
Carrier steam boiler has been working fine for 5 yrs. Suddenly since last week it keeps firing well past the thermostat setting. I changed out the batteries and checked the electrical connections at the boiler. No luck.
Could the sensor be bad?
Steam Heat
New (Burnham) gas steam boiler won't turn off at thermostat temp. Continues to run well past setting. Boilers piped according to manufactures instructions - forced hot water loop off bottom of boiler seems to work fine. Any ideas??0 -
My guess is that something other that the thermostat isn't wired to control the temp. What's wired to T-T on the boiler?0 -
what if
what if u take a wire off t-t one time many moons ago i heard a story bout a bare wire inside the wall touchin causin the furnace to run past themostat setting just a thought royboy0 -
sounds like they dont have a aquastat on baseboard loop and just tied into tt on boiler control need to put aquastat in series to turn boiler on and off0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
