parts for Crane boiler
Lyle C
Member Posts: 96
No Problem ,a bunch of great guys over there I'm sure they can help.
need parts for Crane boiler
Crane Co. no longer makes boilers and can offer no help with info. I have a cast iron 200 Series Crane gas fired boiler (from ~1973) and would like to find a new heat exchanger for the domestic hot water heating component (it's a combo system).
Did Crane sell off their boiler-making operation? If so, to whom? Are parts available anywhere?0 -
Crane
Give a call to Theraflo everhot if they don't have they should be able to make one up for you. Or try their website http://www.tfi-everhot.com/0 -
Lyle, thanks for the tip. --slh0 -
new coil
any coil fabricator can duplicate a replacement coil. especially if you have the plate.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
