WM piping diagram from the manual.
Lil-Roc
Lil-Roc Member Posts: 50
They are correct... the pump is pumping away. At first it looks miss leading but look at the arrows at the diafram tank, in the diagram you see a tee and an arrow. On the compression tank side the tank is tapped off of a different tapping than the supply piping.
