SPUD WRENCH
so I just "angle cut" the nut with a hacksaw(on one side), then spread-it apart with a flat screwdriver. Remove the nut after spreading it open, then come-on to the tailpiece(or nipple), left in the rad with your pipewrench.
  • john_181
    john_181 Member Posts: 93
    Can anyone tell me I can purchase a radiator spud wrench to remove radiator valve nipples?
    Thanks in advance
  • Jim Pompetti
    Jim Pompetti Member Posts: 552
    Spud wrench
    Try the local plumbing supply or cut them out with a saz-all . but be carefull
  • Canadasteam
    Canadasteam Member Posts: 13
    spud wrench
    you should be able to get one of those at your local ridgid tool distributor.
  • You could
    try here.
    Dave
  • heatguy
    heatguy Member Posts: 102
    spud wrench
    spud wrench is made for installation of spud not removal you will just break spud wrench find something that fits tight inside( so you dont crush pipe)get your pipe wrench and go for it. that dont work sawsall is the way
  • heatguy
    Really?
    Been a staple in my toolbox 20+ years,,,never broke one yet.
    Dave
  • Norm Harvey
    Norm Harvey Member Posts: 684
    Likwise, Ive never broken one and its the same one my father had used for years and years.
    I find if anything you shear off the ears inside the fitting before you break the tool.
  • Jim_64
    Jim_64 Member Posts: 253
    spud wrench
    A. I have broken them off, but if you grab the outside of the valve spud with a pliers and stick the spud wrench in with a pipe wrench on the square part then turn both at once it should come out. As to where to get one all the plumbing supply houses we deal with carry them. My latest one was purchased at the big store with the orange sign. All the ones I have ever used were/are made of cast iron. Are the ones youguys have not broken C/I or steel?
  • john_181
    I found one !!!!!!
    The commercial plumbing supply store here (Pittsburgh) has one. The cost is 12.00
    Thanks guys!
    John
  • larry
    My spud wrenches(I have about 6) are steel, step type. On one I had to hacksaw the ½" step off to get it in a particular bb style. I always use a large Crescent wrench on the flats, but like Norm, I`ve ripped out a few ears along the way too.
    Tried those "internal" wrenches Ridgid and others have,,may as well just use a good cold chisel and pipewrench!
    Dave
  • EMB
    EMB Member Posts: 37
    Make your own
    I'm with heatguy on this. My solution (other than the sawzall) has been to take a piece of 2" x 1/4" x 10" piece of flat steel and machine/cut so you have all the popular sizes covered. You can always grind a little extra on site to ensure the perfect fit. If conditions allow, you can also use some heat.
  • EMB
    A lotta screwing around for a $12.00 nipple wrench not broken in 20+ years.
    Perhaps you and heatguy need a lesson in proper tool usage?
    Valve or elbow unions are always brass,,never a prob for myself.
    Dave
  • EMB
    Ouch!! Perhaps we do
  • EMB
    Sorry man, no offence intended,,,I`ve just never broken one!
    Dave
  • Dave Stroman
    Dave Stroman Member Posts: 765
    I think it is safe to say that it is not the wrench that breaks, it is the tabs in the nipple that break. And from my experience, most of the store bought wrenchs don't fit very well. To install the nipples, I make my own with a deep socket and a grinder. I make one for each size and sometimes for each brand of valve I use. To remove them, cut your losses and split the nut off, crank the nipple out with a pipe wrench.
    Dave Stroman, Denver
  • SpeyFitter
    SpeyFitter Member Posts: 422
    removing spud
    Split the nut? How?
    (I'm currently in a fight with a very stubborn spud, and I have a limited assortment of tools beyond a spud wrench and pipe wrench.)
    Thanks,
    Josh
