kewanee boiler model LWB 79
al_28
Member Posts: 1
What type and size is a kewanee lwb79. If water is leaking around tubes could this be a dry-fire. Tahnks
most likely just corroded
May be corroded or just from expansion and contraction. More likely corrosiong. Doubt dry fire but wear most likely. Call in vessel repair company to assess and roll in new tubes if need be. Good luck, Tim0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
