Beckett Afg Setup
JOE_104
Member Posts: 15
check beckett website for technical info password prof/info
hope this helps you
hope this helps you
Beckett Afg Setup
I was trying to find the starup settings for a Weil-Mclain model 68 with a Beckett afg burner. I am having trouble finding this info. The burner is waaaay out of wack. I can not get clean smoke or a good CO reading nothing above 5.8% I am going back again after I eat dinner to try to straighten it out any info would be helpful thanks0 -
try at Oil Tech Talk's
Toolbox, The Toolbox, Library, "Weil-Mclain 68 Series with Becket AFG Burner"
http://www.oiltechtalk.com/pages/oldburners/weil-mclainwithmodelafg.pdf
The .pdf is a little rough on page 4 but page 3 is clean.0 -
end cone
not every time but now and then a end cone has been known to get out of whack check it pump pressure???? is the nozzle the right size?? right pattern?? all these can make a difference have u always worked on it ??or someone else i find if it was always ok b 4 then must be something unusual also i had one one time with a crack at the nozzle line going on drawer assemly when burner started xtra oil came from the fan (squirrel cage) sucking it into yhe fire hope these ideas help royboy //0
