hoffman parts
tim smith
tim smith Member Posts: 2,886
We have no problem getting parts for Hoffman/B&G here in Seattle via Rep. You should have a rep that can help you in your area. Tim
  • Hoffman Specialty conds/vacuum float switch?
    Can't believe I'm having a hard time finding a Hoffman Specialty float switch for their own conds/vaccum system.
    When on this new customer and was given the keys to the building ( meanings I'm married to the job?) and have this steam system buctherd by others, I'm trying to get the the system in working order and the switch rusted and stuck... Its the one that have flange connection, not the 2" screwed connection as you see on the conds pump only unit... Thanks for any input...
  • Marty_7
    Marty_7 Member Posts: 30
    PATRIOT SUPPLY
    Call Patriot Supply on Long Island 516-249-3100. They are one of the best commercial supply houses around.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Easy
    State Supply And they are good friends of this site.
    Retired and loving it.
