Rad doesn't work
GW
GW Member Posts: 5,248
tell us everything (hold back not a thing) that happened to the system from the day that radiator worked, untill now. The answer will be there somewhere.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=368&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
  • Jim Pompetti
    Jim Pompetti Member Posts: 552
    Cold hot water rad
    Twice in one day . The entire system works , well , all but one rad . Not air bound , just cold . All I can come up with is maybe a bad charge in or a bad extrol tank . Any suggestions . First house single floor longest run ,forced hot water , got the call no heat in the back room.System has been in and running for 4 years . Second house 2 nd floor,forced hot water . Said all was find till repair was made , Building was drained to repair leak .
  • martin
    martin Member Posts: 144
    Cold Rad.
    More Input I'm guessing hot water since you mentioned an exp. tank. Location of rad ,forced or gravity flow. Monoflow or series loop. More Input
