Larger Diameter Copper Tube Bender
st heat
Member Posts: 28
i have done quite a bit of research on this. i found that the tighter the bend radius the more bucks the machine costs. you wont find a machine for 1.5" id copper tube for less than 7500 usd. and that machine will not bend tight bends. a mandrel pipe bender will bend that size down to 4x diameter. but that machine is big bucks. these machines are pedrick,pines,mega bender.medi bender. good luck
st.
st.
I'm looking for a copper tube bender capable of bending up to 1 1/2". Also needs to bend up to or even over 180 degrees.
I know I have seen them but can't find anything online. Anyone here use such a thing?0 -
A Company
By the name of "Greenlee" makes benders for the electical trades. they also have some very cool tools for our industry.
Happy Thanksgiving
180º
Josh, most of the benders that I have used don't like to go past 180º. If you go past 180º you can't get the tube out of the bender.There was an error rendering this rich post.
- 167 Indoor-Air Quality
