Takagi distributors?
Steve Ebels_3
Member Posts: 1,291
The source I normally use for Takagi parts and equipment tells me the flow switch for a TK1S is on a national backorder for the last 4 weeks and none are in sight yet. He also tells me that he's tried to locate a flow switch from other distributors and there are none available.
There has to be a flow switch out there somewhere. If you're a Takagi distributor and you have two (2) flow switches in stock for immediate shipment please call my office at 1-800-607-6135 or respond here. I have a laundromat that's down to a single TK1 and it's not keeping up.
Thanks in advance
Thanks in advance
off the shelf?
in a tight pinch, can't you just wire in an off the shelf flow switch with the same parameters?0 -
What is the part # for this switch/sensor??? Paul0 -
Emco
Call Bill at Emco he might be able to help 1-403-252-66210
