Old Grundfos Circ sings like humpback whale on shutoff
Timco
Timco Member Posts: 3,040
At that age with that type of noise, it's time. The cartridge may be all that needs to be changed...
Tim
Just a guy running some pipes.
  • D107
    D107 Member Posts: 1,944
    I'll assume this is not a good thing
    20+ yr old Grundfos UPS 20-42. This unit got jammed at the start of the last two seasons until a medium hammer tap got her going again. Wall wisdom seems to be that old Grundfos circs were known to have low torque on startup. Sings for only a few seconds.
    Anyway, is it time to install the Super Brute II UPS 15-58?
    Thanks,
    David
    hot_rod Member Posts: 26,645
    That's an unusual talent, I'd keep her
    20 years, spend some $$ and get a 15-58 replacement. I'm not sure you would find parts for that model anymore. if so probably not much less than a new pump with a 3 year warranty, 3 speed. anti lock up tickler, etc.
    hot rod
  • Brad White
    Brad White Member Posts: 2,399
    Singing like a humpback whale is one thing.
    When it starts to corral plankton with a bubble net or breaches the surface, give me a call. If it begins signs of obvious mating behavior, call the National Geographic Society hot line....
    Cap'n Bill's Whale Watch boats will probably name yours "Grundy".
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • D107
    I'm thinking of releasing it back to the sea...
    Forget the electric usage; you can't imagine the cost of the feeding. A sad day indeed.
    Thanks,
    David
  • Ross_7
    Ross_7 Member Posts: 577
    Change the pump, Dave....
    Save yourself a headache, and change the pump. 15-58 would be fine. By the way, how old is your car?
    Ross
  • D107
    absolutely Ross
    There's no other choice here--I've changed out the other two fairly recently. Already have one of the superbrutes --nice circ.
    Thanks,
    David
