HEATING
Brad White
Member Posts: 2,399
To my thinking. I do not have the actual UL listing numbers but your code may dictate in stronger language than any referenced standard. Here in MA one needs at least 2 inches clear between masonry chimneys and combustibles (surrounding framing in particular). I have to imagine bare hot (140F) sheetmetal would require more.
IIRC, the standard was that after firing for a period of time to steady state equilibrium, the surface of the combustible material could not be higher than so many degrees above ambient. I forget the numbers, but you may try a UL search or contact a local code authority.
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
Fire safety
Whatis a minimum distance for a wood beam (2x10) from a plenum of an oil fired furnace? Mine are within 1"0 -
depends
It depend's on the make. I have seen a number of them that only require 1". Check the web site for the unit you have...0 -
got a picture?
I general consider a plenum more of a hot air duct/return, and a 'furnace exhaust vent' aa a flue?
since you state "mine are" a plural form suggests you are talking about 'many' plenums? so I am confused my your actual meaning.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
