Mouat Vapor System
Steve_167
Member Posts: 1
I'm looking for steam traps from a Mouat Vapor System. Does any one have any ideas where I might find them?
If they don't have em////
they'll make em. T.P. Tunstall is the best. ask for Woody. Mad Dog
mouat traps are a unique size
and tend not to line up well with a modern replacement..if you have water seals there are no moving parts, and they would only need cleaning..if you have thermostatic traps, i get my parts from barnes & jones..if your putting on a new trap you'd want to use something with approximately the same venting capacity as the mouat traps elsewhere in the system..for example, if the system has outboard traps, a suitable replacement would be barnes & jones #122, or monash #34 or #38, nicholson #n125,or a sterling #7-50-a..this way the existing balance isn't messed with.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
Listen to Gerry
he is our resident Mouat expert. If you're near Cleveland, home of the Mouat, get in touch with him if you need work done on your system.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
