My first Crete-Heat job
Rod, what do you know about EPS under slabs?
I've heard murmuring about expanded foam not handling moisture very well, but I haven't seen anything to confirm or deny that. I know we've always specified extruded, not expanded polystyrene, but I'm open to options.
any good info on this? Cause it does look like a cool product for sure.
and I'm a believer
this is a 900 square foot Habitat for Humanity job.
Crete-Heat donated the panels, Watts Radiant the Onix and manifolds. I'm doing the work Caleffi is offering a Solar Pump Station for the SDHW. A fun LEEDS project involving the a local Drury college architectural class.
The panel went down in about 1.5 hours, and less that that to walk in the tube.
What a joy to not have to handle rusty old mesh and finger filing zip ties.
I'll do a 3200 square footer in a week or so also.
hot rodBob "hot rod" Rohr
Crete heat
I saw that product a while ago and found it quite interesting. Do the wire the rebar over the top then after tube lay out. ??? Tim0 -
It could have
mesh or rebar placed over the top. This job will have fiber blended in the concrete instead of rebar of wire. fairly common to do it that way around here.
The posts on the Crete-Heat would hold the bar or mesh up into the pour very well. So often on plain foamboard it lies at the bottom of the pour doing little., if any good.
I believe
Did a 900 sq ft garage recently.Was fun putting the tubing in.It was poured with fiber mesh concrete.Don Regan from Crete Heat wanted to come look at the job but I was away at the time.Great company,great product!!0 -
what tubing?
that looks like flat tubing hot rod? what kind is it?
looking like it would be easy to trip and pull up tubing?
looks good though0 -
Closed cell foam...
does not take on moisture. Your getting todays EPS confused with yesterdays bead board. www.epsmolders.org
Remember the last time you had a hot cup of coffee or hot chocolate from a white beaded cup. Did it drip? Did your fish box or beer cooler leak? What's in most boats made today to keep them afloat? They would never use EPS in these products if it took on water. Personal watercraft are filled with EPS so they don't take on water if submersed.
Thanks for asking.0 -
water heater
I have a radiant system using a water heater. Wondering if i put a loop to my furnace with a heat exchanger if i would benifit. If so where would i find one0 -
Very nice looking install. *~/:)
This is a sharp product....i have looked for a long time to find something like this....
quietly the wheels of time turn0 -
This tube is
Watts Radiant Onix, 3/8" A very tight fit. I doubt it will float or snag on boots. it lies very flat to the board.
My next install 3200 square feet will be with Viega 1/2' fostaPex. I'm anxious to see how the tube installs compare.
insulworks
Beaver Plastics makes a similar product and distributes throughout North America. A real time saver on installs. http://www.beaverplastics.com/beavercurrent/insulworks.html0 -
good to "see" you again donI did some more poking and I now see the light, thanks!
goto
main menu and post your question. off hand the answer is no, standard water heaters are only about 70-75% efficient, if your furnace is lower best bet is to upgrade your furnace.
and keep your radiant separated from you shower water!0 -
More Pictures???
I'm looking for more install photos if anyone has some.
Thanks, Don0 -
more on their site
If you haven't already looked Crete-Heat has pictures on their site. http://www.crete-heat.com/pictures.html0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 392 Solar
- 55 Water Quality
- 46 Industry Classes
