Hydonic Baseboard - Trim only
Kyle_7
Member Posts: 1
Thanks for reading; ran across some baseboard that I am not familiar with. All the 3/4" copper tube is exposed along the wall supplying fin-tube baseboard, but the copper is covered with "trim" no openings along the top like typical baseboard, but fully enclosed. We could just install enclosures only, then the fin-tube were needed, but like to find what was original installed. Currently all the baseboard is damaged due to a recent fire. You know of who offered this trim?
Thank you, -Kyle
Thank you, -Kyle
Kyle
If the system(and it sounds this way),, is originally a loop system,, in-one, out to the next, then so-on around that zone,,, it was not uncommon to run the piping on the face of the walls then have them trimmed-in by the carpenter.
Don`t concern yourself to the output of these pipes,,, only the actual active element within the enclosures themselves.
For cosmetic reasons the enclosure can be run on the entire room perimeter,, but the actual heat-output is gaged from the F/T element itself. :-)
Dave0
- 50 Industry Classes
