Help with RFH design
What would you consider small? Total area of existing + addition will be roughly 1600 sq.ft.
Hadn't thought about the electric yet.
Thanks
  • David Hawks
    David Hawks Member Posts: 2
    RFH
    Greetings, 20 year remodeler here, attempting to venture into the world of RFH for a spec. remodel (flip) I'm doing in NC.
    Existing is wood frame w/ accessable joists 40x32. Proposed addition is to be slab-on-grade 16x32.
    Natural Gas available.
    From my limited research, I like the thought of combining the RFH with DHW. One zone???
    Air handler in attic w/AC ducted through ceiling.
    $$$ dictates that this project be DIY.
    My "friends" on Breaktime said that this was the place to get answers to all my questions, as well as ones I haven't even thought of yet.
    Please tell me: am I even on the right track with my plans here?
    Almost forgot, this technology has NOT come to this part of NC yet, so I'll be ordering EVERYTHING.
    Thanks
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    in my opinion...
    RFH is not a inexpensive thing that can just be "flipped"...not the cheap thing...if done right. You suggecsted combing the radiant w/ the DHW...you still need to seperate the two by way of a Heat exchanger...open systems are NOT a good idea...if the area is small and the load light elecrtic radiant might be the better idea...kpc
