stick on thermometer
allenh
Member Posts: 117
Does anyone know of a source for stick on thermometers? They were a couple of bucks each when I found them a few years ago.
Try Watts radiant. I think they are called "stick temps".0 -
Depending on what you want them for, you can find them at pet stores. They use them on fish tanks.0 -
McMaster...
McMaster-Carr has'm too if I recall -- liquid crystal color bars for the temps. Thay may also have strap-on/clip-on dial types too.
http://www.mcmaster.com0 -
thanks !
found them here..
http://www.mcmaster.com/#59485K26
They are soooo handy to toss on a pipe instead of trudging through the snow to the truck for the hand held temp meter.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
