Boiler wiring
martin
martin Member Posts: 144
From your descrip. you have a multi temp system, so I expect some form of mixing apparatus is in place. It depends how it is plumbed to how its wired, but is ussually not horribly complex
  • Scott OB
    Scott OB Member Posts: 22
    Wiring Knight boiler
    Just had a new KBL-105 installed.The plumber isn't sure how it should be wired.
    It has primary/secondary piping.A radiant heat loop with a Taco variable speed circulator with outdoor reset.The boiler also came with an outdoor reset.There is 4 zones of HWBB with seperate circs for each zone.1 zone for modine wall hung garage heat.3 zones of radiant uponor quick trak with tile.1 zone of radiant quick trak with hardwood floor.1 zone of radiant garage heat.1 zone of indirect DHW.The plumber has a Taco muti zone controller for the system.Should we be using a Tekmar for total control?Any input wold be helpful.
  • Timco
    Timco Member Posts: 3,040
    Not many sparkys are familiar with hydro wiring...be sure to save all the schematics for him and call a good one!
    Tim
    Just a guy running some pipes.
  • JK_3
    JK_3 Member Posts: 240
    I always do all of my own wiring and in a case like this i would have to see each wired componants specs and under stand the seq of operation you are trying to achive but if you are using a taco circ controller it comes with diagrams to cover most applications. if your plumber is not used to wiring boilers outside of basic boiler wiring you might want to find someone who is or at leastcontact tech support for each of the componants manufactures and get thier input. Good luck
