? on peerless boiler chamber kit
John@Reliable_14
Member Posts: 171
give them a call, very good to deal with. Tech support will be able to tell you what you need.
Sorry no toll free, they are in Lynn,MA
Phone: 781-593-2500
FAX: 781-596-0430
Phone: 781-593-2500
FAX: 781-596-0430
? on peerless chamber rebuild kit
I went to look at a Peerless boiler and determined that it needed a Lynn chamber rebuild kit. Looked like the Peerless boilers that I have done before which need a rebuild and did not think much about it, took down model number and left. I gave the supply house the model # TW-3. They do not have a cross reference for that boiler to a Lynn Chamber kit.
They gave me the PO kit and said it should work. I would like to confirm this before I drive 2 hours to the job. I cannot find any online cross-reference. Is anyone familiar with this model TW-3 and the chamber kit it requires. Thanks
The TW
is actually a later model JO/JOT series. The chamber for that should work OK.
If that boiler has any burner with lower static pressure capability than a Beckett AFG, Carlin EZ or Riello, I'd upgrade the burner as well. Lesser burners can cause these boilers to plug up with soot.
Yup that one did fit, thanks.0
- 167 Indoor-Air Quality
