From our friends at Taco (Dan H.)
John Barba
Member Posts: 166
> an VS SR 6-o6 exp for a mutiple variable speed <BR>
> flow control center .? <BR>
<BR>
Wanna run that by me again? A six zone expandable relay for the 00-VS variable speed circulator?
<BR>
Build Your Hydronic Business;
Join the Taco FloPro Team
* Develop as a hydronic professional
* Win more hydronic jobs
* Increase the scope, performance and value of all your hydronic jobs
* Build your business with consumer education and professional promotion
* Increase your profits
* Earn valuable rewards
* All without spending a dime
How? Join the FloPro Team , Taco's new growth and development program that's designed to drive your hydronic business to the next level of performance and profitability.
As a member of the Taco FloPro Team, you can get what you need to grow your business:
--From the inside, with in-depth training, reliable field and technical support and exclusive hydronic design tools,
--From the outside, with consumer education that raises the value of the solutions you sell plus persuasive, professional, promotion materials that will make your company more visible in the market.
And you can earn valuable rewards for yourself while you do it.
It's simple to join the FloPro Team. It takes just a few minutes and you can do it online right now by filling in this Quick Registration Form . It takes just a few minutes and you can do it online now by filling in the form.
The engine that powers the Taco FloPro Team is G.E.A.R.S.our program of Growth, Education, Assurance, Rewards and Support.
* GROWTH Professional growth for you, more and more valuable hydronic installations for your business
* EDUCATION Flexibly-designed FloPro training to fit your level of expertise and work with your hectic schedule at locations throughout the U.S.
* ASSURANCE The quality and reliability you've come to expect from Taco through three generations of family ownership.
* REWARDS Sales incentives, great-looking hats, jackets and other wearables that show you're a highly-trained FloPro professional.
* SUPPORT that runs the gamut from expert tech specialists, responsive FloPro reps, and powerful, easy-to-use design software, to consumer education, advertising and promotion.
You've got nothing to lose and everything to gain. Learn more about the FloPro Team by clicking the link above, or join the team today by filling out the online form. You'll kick your hydronic business into high gear right now!
Thanks for your interest. See you on the Taco FloPro Team.
John BarbaRetired and loving it.0 -
Hot Spit!!!
Nothing to lose here.
I've seen the new team in action and have to say that it's a great way to get going.
As an added attraction, you'll get some John Barba training(?) time. He'll incorporate things you'd NEVER think of... to make his point. That alone is worth the price of admission....and it's free! (Ask him...he'll tell you the same thing...and FULLY explains it in his seminars!)
If your trying to break into some radiant and hydronic areas that have been traditionally "warm air holdouts", give it a shot. Chris0 -
Thanks Chris ---
Hope to see you again soon!
JMB0 -
John, has anyone given any thought to the idea of
an VS SR 6-o6 exp for a mutiple variable speed flow control center .?
Been there......Done that
It's a Win-Win situation.
Thanks Taco0 -
Thanks back at you...
Thanks Steve...
JMB0 -
Basically ....
for a central building management system of variable voltage variable speed small wet rotor circulators.
then with multiple runouts in a large facility the flow rates to the individual headers could then have the advantage of a central interface within or near the boiler room.
with the use of pex the delta T's back to the various remote locations might be better able to take full advantage of multi minitube injection systems Low Loss headers and a variety of new and interesting products that may be available on the market in the near future.
i have not seen that offered. so i considered the possibilities of :variable speed drives and different building management systems, the hierarchical command structures that are required to make certain things do what You want them to do without investing way too much time and dollars integrating a variety of different products to have centralized control at a reasonable effort and expenditure in time. it is not a typical homeowner type deal however, perhaps there could be a simple selection that could use 6 00 10's 0r 6 of the larger size wet rotors circs. my thinking is that by say using smaller 1 1/2" pex tubing or 3 " or 1/2 " whatever..large facilities could have a niftty way to dial a variety of diff circs that could feed larger Load match systems in different parts of the structure.
Wow Steve, i thought this idea was somewhat unique. would you show some pics?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 947 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
