Small outdoor boilers
mtfallsmikey
Member Posts: 765
Looking for a small OWB, like the Pro-Fab (mfd.in Canada). Small house, don't need one of the larger behemoths like most folks buy. Any input appreciated.
gasifier
I'd consider a gasifier. They burn a lot cleaner and are much more efficient. You need dry wood for most of them. There are several new outdoor models--more all the time as the smoke monsters get banned around the country.
Blue Forge is one. Adobe and Black Bear Boiler are others. New Horizon has a modified indoor rig that looks pretty cool:
http://www.newhorizoncorp.com0 -
Greenwood is another gasification unit, http://www.greenwoodfurnace.com/. Depending on your BTU need the profab ECB-200 is a outdoor gasification unit, but may be too big for your application.
Joe Billow0 -
An AquaTherm
brand can be purchased unsheltered. This allows you to build your own enclosure. AquaTherms are pressurized OWF's.
The Royall from www.wdheat.com is a small size that could fit in a small enclosure. They sell it as a pressurized or non pressurized vessel. I had one at my home for a bit. Fairly small firebox, however.
One of the few that has an ASME listing (pressurized version) and UL if your insurance company needs that.
hot rodBob "hot rod" Rohr
Hot Rod: Why did you...
Stop using the Royall?...look like it would fit my application well...also, has anyone used/seen the Ecoburn?0 -
I'll still sell a Royall
I prefer the gasification units for efficiency, features and emissions.
With the small fire box it is sometimes hard to get a full day burn with the small Royall.
It is a nicely built unit. Heavy steel, nice door, great track record.
Central boiler had a nice pellet/ corn burner boiler at the FarmFest last week. They build their own feeder and control module in the US. It actually uses a small Lp tank for the ignition system. Fire tube boiler design.
Central claims they sold 12,500 OWF and boilers last year!
