Plugging vent on steam radiator
but why not get and adjustable vent and turn it down so you can open it some if you desire
  • Charles Weedon
    Charles Weedon Member Posts: 1
    Is it safe to remove the vent on a one pipe steam radiator and plug the hole. I am hoping to keep the radiator air bound so it will put out very little heat. The valve is stuck and the room over heats.
