buderus r2105
Al Letellier_9
Member Posts: 929
Sure sounds like you have diagnosed the problem. Call Buderus tech support at 1-800-Buderus and run it by them. They are the best source for detailed tech support and troubleshooting...some of the best in the business.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=522&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
display--heating err
I went to a call this weekend with a r2105 displaying HEATING ERR. Checked the man/reset high limit-ok. Turn control off/on.
Hot water is calling, but no power out of the burner terminals. I have continuity across internal fuse, but no power to or from terminals. The display shows the flame signal,and the call for heat has been acknowledged. When I put it to manual, burner fires. Any ideas, I was thinking bad module.0
