Closely spaced tees
Why two? Insurance? FYI, so far, unless it expands, the HW plant would need 120 GPM under full load. Will I find a pump that big with IFC? (I'm looking for my charts now...) ;)
Does...
Closely spaced tees work for 8" pipe or will I see some flow?0 -
Same principle
scaled up or down.
If the flows are really tiny, I could see some internal convection within the pipe volume, but for a flow rate proportional to the pipe size, the closely spaced tees properly set up should work as well as smaller pipe sizes with which you may be more familiar.
Is there a particular job on which you have a concern?
I have one starting up soon, 6-inch mains which I expanded to 8-inch for the tees. Two 358 GPM boilers feeding a school via P/S tees."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
6\" Mains
Ideally, your T's should be 24" or less. I have used the rule of 4 pipe diameters on every pipe size I ever encountered. No problems. What's the flow in the primary and what the flow in the secondary0 -
Thanks...
Not sure of any numbers yet, I'm looking at adapting the air to water heat pumps to a 700 ton chilled water system and thinking of just teeing it into the return main with close spaced tees. The building uses electric duct heaters. One A/H totaled 1.2 million BTUH between preheater and reheater and there's a few A/Hs. They want to convert to gas for some reason...
I'd still like to see
gravity gates, AKA check protection on both S&R. Maybe a circ with intergral check on one side and a stand alone check or flo-check on the other side.
hot rodBob "hot rod" Rohr
3\"...
pipe. Piece o' cake! Slice of pie. Walk in the park...
Doubtful on the IFC
in that size circ. Ghost flows are what you want to keep in check. Early on P/S without checks was promoted. then one check. then one check and under slung take-offs. Really two checks prevent any un-wanted flow and are easier to put in on the initial installation.
Absolutely!
(in my best Rocky voice). Much easier to do it at the get go. 3" is nice but I like 4" better. Call me the king of overkill but it's got a ways to go. It'll keep my pump size down. Thanks HR!
m0 -
My wife
resembles a closely spaced Tease.....
Film at eleven. I'll be sleeping on the couch at 11:01.
Pablo0
