first condenser...
Mike T., Swampeast MO
Member Posts: 6,928
What sort of bypass?
No need for bypass to keep return temps up with a mod-con.
Differential pressure bypass generally only required when TRVs are used on all rads.
Looks like I found a happy medium for my customer...
http://www.johnstonesupply.com/corp/tabid/1780/default.aspx?Product_Code=L97-828
Would this guy want a bypass? I am trying to price this job out. 4 zones, CI rads, future indirect. May use size larger, will be doing the heatloss this week.
Thanks, TimJust a guy running some pipes.0 -
Link doesn't work, what are we supposed to see?0 -
Try again. It worked for me.0 -
So a direct return system with typical thermal migration protection is all? I have not seen the manual, and do not know the flow rate for this boiler yet either.
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
