3 coil indrect
Ron Schroeder
Member Posts: 995
Unless you want to run glycol in the boiler too, you will need 3 heat exchangers.
It would probably be cheaper to use a 2 coil indirect plus a flat plate heat exchanger rather than a 3 coil indirect.
You could replace one of the pairs of closely spaced T's in a primary loop with the flat plate heat exchanger to get the third input.
3 coil indrect
concider a 3 coil indrect dhw tank for a home with radiant floor heat.bottom coil is for solar input, center coil is for mod con boiler input and top coil is for radiant loops.Tank may have to be large, 100 gal. Will it work? has anybody seen a tank like this?0 -
Would this work?
http://www.acv.com/int-en/03_05/243/app.rvb
If so, let Triangle-Tube know that there is a market for it here - get them to start bringing them over.
The 400 litre (100 gallon) size exists already.0 -
a 3 coil tank would be pricey
Wouldn't a 2 coil be enough if you pipe it P/S for the 2 heat sources: solar and mod/con? Several stock 2 coil units out there.0 -
triple coil indirects wouls be nice to have
I suspect a 3 coil 80 gallon tank would be in the excess of 2 grand, however.
Looking at the cut aways of those Euro triple coil tanks they have a boatload of coil in them. They look to be at least 1-1/4" diameter coils too.
Lots of HX surface makes for a great tank. Able to harvest low temperature solar, able to take a lot of boiler input and perform quickly. Easy to pull low temperature radiant off a large coil, etc...
Creative piping could get you there. Maybe a 3 way zone valve, or an external HX.
3coil
part of the idea is to have less equipment out side the tank. solar will provide for the heat loop without running boiler loop.tank may also act as buffer for boiler short cy.
I suspect listings and
the number of tanks that would be sold in this market is what keeps those large tanks on the other side of the pond.
There was a dealer at the REX show in CT. last month that had a 750 or 1000 litere cut-away triple coil tank in his booth. That's the first one I have actually seen in the US of A. Didn't sound like he had plans to import any.
hot rodBob "hot rod" Rohr
3coil
an HTP phoenix with coil top and bottom is needed.solar loop is glycal and cant share loop with boiler0 -
Will the solar be drainback?0 -
solar
solar loop is closed gly. the main reason for doing a system like this is space savings. this house is on slab, no basement, small utility room to work with. This progect is on the west coast, frost lines are not deep so many new homes have no basement.0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
