Can the high limit switch be replaced on a honeywell aquastat?
by an L8148J relay. No the limit by itself can't be changed.
The high limit switch is not turning off the burner when water temp. is reached. Can the high limit switch be replace or does the entire relay need replacing? Honeywell L8148E Aquastat Relay0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
