Coil Bolts
Chris_82
Member Posts: 321
If there not 9/16 then 3/8 is a very common size.
Coil Bolts
What Size Threads Are Coil Bolts On A HW Coil On A Peerless WB?0 -
bolts
Odd you should ask, I just removed a coil from a peerless today. The bolts on the X-1091 coil are 9/16" They are 1" long. The boiler was a peerless wct-03-110. I did not measure the thread pitch.0 -
Whoops, the pitch I do believe is 1.250
- 120 Geothermal
