Installing a Pigtail
Kool Rod
Member Posts: 175
I thought maybe it had to be filled with water first to work properly or prevent any damage to the gauge.
Getting Water To Stay Inside
Hi. I'm installing a low pressure gauge on one of my rads. I feel dumb asking this question, but how do you get water into the pigtail? I poured a little bit in until it came out the other end, figuring there would be a resevoir left in the pigtail, but when I turned it upside down to see how much was trapped, almost nothing was there. I guess once the water gets flowing it all flows out. So I'm stumped. I'm using a 6" pigtail. Maybe I need a larger size?
Thanks.0 -
Pigtail
Reminds me of the ejector seat instructions on a clear decal pasted to the jet canopy. Step one was to eject the canopy and by golly, there went the rest of the instructions with it...
Install the pigtail first, (with the system off and cold of course), then pour in water and then install your gauge. The siphon tube (the "loop") will hold what it does.
Pre-filling it then turning it upside down will demonstrate more about gravity than thermodynamics.
In normal operation, a few cycles of operation will fill the pigtail and that is that.1 -
Thanks. That is what I'll do.0 -
brad
i'm new to steam, but wouldn't it fill with steam during operation and turn to water/condensate 'fill' on it's own?0 -
yes
actually,
i missed the gauge specification in the initial post, and i'm refering to the siphon tube on the pressuretrol. the gauge on the boiler that i was working on didn't have a tube on the gauge0 -
Let it fill on its own. You do not need to prime it. The very first wiffs of vapor coming off the water surface will condence and fill the loop long before any pressured steam can get past to do any damage .0 -
Picture of Pigtail
Installed and ready to go.0 -
new concept
on a radiator... i love that !!0 -
Soooo-weeeet!
Nicely done, Frank.
BTW: the only reason I recommend priming a gauge is if it is of the kind not rated for steam temperatures. Some have a limitation of 140 degrees or so. The priming eliminates that first charging with steam, takes it out of the equation.
In truth, I have seen many "naturally primed" in operation without incident, but in practice, I have to follow the equipment listing.
For normal gauges actually rated for steam temperatures and self-priming is ok by me.
PS: Can you post a picture of the gauge, "in action", so we can see what you get?
My inner engineer says that a live web-cam would be the equivalent of "engineer porn"0 -
I got the idea from nbc.
Thanks go to him.0 -
steam extremist
i think i will one up him & relocate my boiler w/ six inch drop header to my living room.0 -
And you know what?
You really would!
(I would too, or move my living room to the basement...)0 -
A different take - You've got to be kidding if you want to try..
I read the tittle of the thread and here is the scenerio that popped into my head.
First you have to get a pigtail. So you have to catch a pig, wrestle with it to gain control so that you can cut off the tail. Assuming of course that you could succeed in the first place.
Now; tail in hand you are asked to reinstall the pigtail...
Oh man... Do I want to watch - while you try to reinstall that pigtail on that pig....
Perry0 -
Today I learned something new....
Perry has a sense of humor!
Dry, Perry. I like that.0 -
more instruments for the \"dash board\"
taylor make a range of indoor/outdoor wireless thermometers which can be used to monitor different areas of our bldg. about 4 brick walls can be transmitted through before they lose the signal. i can see from my living room the temps [including max/min] in 3 apts on the 2nd floor above me. i have another set on different frequencies to check the outside temp, so as you can see, i am a great believer in instrumentation! i don't mind going down to see the boiler, and gaze in silent contemplation at its warm power, so i will not even bother to ask "she who must be obayed" if i can move it upstairs!--nbc0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
