VISIONPro 8000 Question
carol_3
Member Posts: 397
On Chronotherm IV you could choose number of days or infinite hold. As I remember, that was an improvement over Chrono III that just had indefinite hold. And as you mention, vision pro has yet another level of hold options.
Hi Carol,
When the VISIONPro 8000 is programmed to hold a certain temp for a number of days, is it in increments of 24 hours from the time of day that it was set? How exactly does it work?
Thanks, Adam0 -
I'm not absolutely certain, but I'm fairly sure that it's simply a timing function in 24-hour increments.0 -
I just looked on page 14 of the latest Vision Pro Manual On-Line
and it shows you can now set the time you want the thermostat to go back to program mode, after the number of days has expired.
However, I'm almost positive the earlier versions would go in 24 hour increments from the time "Hold" is pushed.
Vision Pro 8000 Operating Manual0
- 15.8K Strictly Steam
