Compressor
Ken D.
Member Posts: 836
Or a capacitor that is bad or mis-sized. Check with the mfg. for the proper cap specs.
Amperage
What could cause a compressor rated for 28 Amps run at 56 Amps?0 -
sounds like
the start winding is staying in the circuit0 -
NATE!
Wrong start/run/relay components! Mis-wiring!A bad comp! A wrong comp for the application! Bad components!Or even a bad meter!And others!0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 988 Plumbing
- 389 Solar
