Tubing in stone wall
Terry Larsell
Member Posts: 54
I remember reading about someone putting tubing in the fireplace wall. I have a job where this is a good option, big room lot's of glass. The heat source is geo and he only wants to give me a 100 deg water, we are pushing him for 110 deg. If I heat the masonary wall and get the 110 I think it will work. The mason is on board if we fasten right to the block, he's not liking the talk about insulation. Any experience out there?
Terry
Terry
Radiant
Installing radiant walls in aluminum plates might be a preferrable option.0 -
Take a look at Ziggys web site
John has an article that shows how to do radiant walls and this might help you , make sure you do a heat loss on the building befor working with the system , I treat the geothermal guys like anyother utility they must deliver x amount of Btus and x flow rate and provide x temprature continuiously for each job , this has worked out well for us0
- 167 Indoor-Air Quality
