Biasi Boilers and Triangle Tube Indirects
Tom Hopkins
Member Posts: 554
both fine.I install many of each with no problems.Biasi is not a "knockoff" of anybody.If you mean the design appears similar,what 3 pass isn't?If you took the jackets off a dozen 3 pass boilers,most people in the trade couldn't identify them much less a layman.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=313&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Biaso Boilers and Triangle Tube Indirect
Any comments on Biasi Oil Fired 3 section boilers and Triangle Tube Indirects?
I am considering both and just want to get feedback, pro and con on how they compare to comparably spec'd boilers and indirects from other manufacturers.
How realiable are they?
I am also considering Buderus.
THANKS!0 -
go w/ the Buderus, Biasi is a knock off of Buderus but I don't think it has the flexible iron & as much insulation. You might as well buy what biasi is trying to copy...0 -
Robert, I think that's the same guy
who said the same thing about the Burnham MPO. What he's forgotten is that 3-pass cast-iron boilers have been around for at least 100 years ;-)
We have installed several Solaia boilers which are based on the Biasi casting, and they work great. Same with the TT indirects.
The TT's are great
especially the TR series. Biasi has the advantage of the lighter weight and lower water volume. I'd rather have extra boiler water volume in the indirect not in the boiler.0
- 167 Indoor-Air Quality
