Compressor
Or a capacitor that is bad or mis-sized. Check with the mfg. for the proper cap specs.
  • Barrington White
    Barrington White Member Posts: 37
    Amperage
    What could cause a compressor rated for 28 Amps run at 56 Amps?
  • Mitch_4
    Mitch_4 Member Posts: 955
    sounds like
    the start winding is staying in the circuit
  • Techman
    Techman Member Posts: 2,143
    NATE!
    Wrong start/run/relay components! Mis-wiring!A bad comp! A wrong comp for the application! Bad components!Or even a bad meter!And others!
