Blocked Circuit in Radiant Snow Melt System
Bob_119
Member Posts: 1
We have a snow melt system using 3/4" Onix tubing. There is one circuit that won't heat and my assumption is that the tubing is kinked. Any ideas as to how to locate the kink? The circuit is about 380 lf and an electrical fish tape won't go thru the bends. When the circuit is pressurized to 100 psi there is just a trickle of flow so I'm assuming that thermal imaging won't work.
Jack hammer surgery...
Unfortunately, at present, there isn't a way to locate a kink with thermal imaging (you can't get flow anyway) nor with doppler ultrasonic testing...
ME0
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
