primary pump question
Steamhead (in transit)
Member Posts: 6,688
Wire your zone panel to pull in the R845A. One contact in the R845A is fed with line voltage for your circ (I'm assuming this is the usual 120 volts). The other contact is wired to start the boiler. Simple!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
What's the simplest/best way to power a primary circulator from a multi-zone, multi-circulator system? Need the primary to run when each secondary zone is calling but I can't power it from the boiler.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
